New OBD2 gauge installed - Aeroforce Interceptor
Old 02-08-2009, 08:55 AM
  #121
eDiveBuddy's Avatar
Default Mine are finally mounted
Finally got my gauges mounted. After I did this I found gauge cups I liked better a egauges.com, but I'll keep these for a while. They tilt and swivel. I might cut the stalks down a little
Old 02-08-2009, 10:53 AM
  #122
scotlandjk's Avatar
hi
i am really interested in how the device displays the data about yaw/tilt steering position etc. can any one who has one post a pic of what it shows
thanks
Old 02-08-2009, 07:32 PM
  #123
tambil68's Avatar
I'm not sure what yaw/ tilt steering position is? But if I remember when I hook mine up this week I will check it out and take a pic for you.
Old 02-19-2009, 09:57 PM
  #124
chuck45's Avatar
I just got one of these and have it mounted. I'm on platform 2 but can't read tranny temp. Well that isn't exactly true; it reads a constant -19.4. I notice that there are 3 or 4 things that might be the correct tranny temp. Which did those who have it working select?
Old 02-20-2009, 06:24 AM
  #125
undertow119's Avatar
Trans Temp V6
Old 02-20-2009, 08:15 AM
  #126
chuck45's Avatar
Originally Posted by undertow119
Trans Temp V6
Thanks, I just tried it and it worked. I didn't try it because the manual I DL'd said it was for Dodge 08 and up PU's. The manual for this unit sucks. It is not nearly as detailed or informative as it could be.
Now I need to figure out what other things, other than coolant and trans temp, would be worthwhile. Do you have any suggestions.
The most important thing was/is trans temp. I wanted to get it working today since we are going to Moab for the weekend. I want to monitor the trans temp while crawling before I install the B&M trans cooler I just got.
Old 02-20-2009, 09:11 AM
  #127
artpics's Avatar
Originally Posted by eDiveBuddy
Nice Mounts.
Old 02-20-2009, 04:36 PM
  #128
AZJeeper's Avatar
This thread might help. I found a couple that I thought was working really aren't, but it is mostly correct.
https://www.jk-forum.com/forums/modified-jk-tech-2/aeroforce-interceptor-parameters-demystified-68118/
Old 02-20-2009, 06:42 PM
  #129
tambil68's Avatar
Originally Posted by scotlandjk
hi
thanks
ok, I didn't grab a pic, but it shows tilt as degrees. So when the steering wheel is centered, it reads 0.0 turn it left, and it reads say -1, -5, etc. turn the steering wheel right and it reads 1, 5, 45, etc.
Yaw, reads as 0.0% but I still don't know what that is. My will move to 0.5 sometimes.
Post up, if you still want a pic.
Old 02-21-2009, 01:04 AM
  #130
scotlandjk's Avatar
thanks man
i asked about getting one of these for the diesel but they said it probably wont work cuz the computer is different
Quick Reply: New OBD2 gauge installed - Aeroforce Interceptor
