New KC Slimlites not working
Old 06-30-2011, 06:30 PM
pjwing's Avatar
Default New KC Slimlites not working
I installed some new KC Slimlites today. Everything went well except only one of the two lites illuminates. Any thoughts? Thanks!
Old 06-30-2011, 10:03 PM
JK-Ford's Avatar
Sounds like the switch and the relay are working. So it has to be in the circuit to that particular light. Check the connections at the relay and the light.
Old 06-30-2011, 10:15 PM
dizk's Avatar
Not sure about the slimlites but with my daylighters both connections are like splicers and the lights have a little metal plug you push in. If its the same maybe the splicer for the second light didn't go through the wire all the way or the plug wasn't pushed in all the way. Just some ideas. Good luck
Old 06-30-2011, 11:04 PM
HeyBob's Avatar
Like they said check those blue clip splicer thingys but also check your grounds or try an alternate location.
Old 06-30-2011, 11:41 PM
JK-Ford's Avatar
Are you guys actualy using those things? Those should be labeled "For Shipping Only". As soon as you pull them out of the box, your suposed to cut them off and throw them away.
Old 06-30-2011, 11:57 PM
TURTLECON's Avatar
You mean the vampire (tap) splicers? Those suck. No pun intended.
Old 07-01-2011, 02:12 AM
JK-Ford's Avatar
Na. I think that they are talking about the male and female bullet connectors that are installed on the fixtures from the factory.
Old 07-01-2011, 07:01 AM
pjwing's Avatar
Much appreciated. First I'll check the fuse for that light, then I'll remove the "plugs" and splice the wires if needed.
Old 07-01-2011, 07:38 AM
westchester's Avatar
Starting with the basics, did you connect the non-working light to the working light's wiring ? At least you then know if the non-working light is at fault or not.
If it now works, then you know the problem is in the wiring so look for a bad connection, bad ground, bad fuse, bad relay, etc.
Old 07-01-2011, 08:23 AM
TURTLECON's Avatar
The two connectors coming off each light?
Quick Reply: New KC Slimlites not working
