Need wire diagram taillight US EU
If you're going to do the swap let me know how it turns out, or if I can help.
Dennis
Ps. I can check the wiring diagram tomorrow and see if there are part numbers mentioned.
It seems I may be a day late and a dollar short, but just in case. Here is some pics of the taillight of a 2007 JK (US).
Here Below is the how each part is wired. X=Blank, WG=White w/Gray Stripe, WY=White w/Yellow Stripe, Bl=Black, WO=White w/Orange Stripe, WG=White w/Green Stripe. (Top of Harness, for the sake of my shotty labeling is the two large holes)
Input from Harness
WG WY X
Bl WO WG
Output from Connector
X X WG
WY WP Bl
Tail Light Input
WY
WP
Bl
Reverse Light Input
WG
Bl
Input from Harness
WG WY X
Bl WO WG
X X WG
WY WP Bl
Tail Light Input
WY
WP
Bl
Reverse Light Input
WG
Bl
Attachment 338793Attachment 338794Attachment 338795Attachment 338796Attachment 338797
Input from Harness
WG WY X
Bl WO WG
X X WG
WY WP Bl
Tail Light Input
WY
WP
Bl
Reverse Light Input
WG
Bl
Input from Harness
WG WY X
Bl WO WG
X X WG
WY WP Bl
Tail Light Input
WY
WP
Bl
Reverse Light Input
WG
Bl
In order to convert mine for the UK I simply tapped into the front turn signal running a wire to the rear connecting it to the disconnected reverse lamps. Once connected I replaced the bulb with a amber bulb. This will remove the reverse lights which I solved by adding a single fog light in the middle of my bumper to act as a reverse lamp. This has been working fine for the last two years or so. The turn signals flash as though a bulb is out which was annoying for the first month or so but now I don't really notice. I was told you can place a resistor in the line to prevent the fast flashing but it did not bother me that much.
I have driven across to France and have had no issues.
One of these will fix your problem, if you can acquire such a thing in EU. Just hook the leds into the output side of the converter or wire up a 4flat to them for easy removal.
Walmart.com: Hidden Hitch Taillight Converter with 4-Flat Car End Connector-119130: Automotive
I can draw up a diagram if you need help.
I would like to see a wire diagram copy, if you have one I would be appreciated it.
Thanks already
PS found it already
