need new battery, optima yellow top?
#32
Originally Posted by The Green Monster
Not to hijack, but if one were to use a dual battery setup, would using a starting battery for primary and a deep cycle for lights, winch, etc. work? Obviously assuming the dual battery relay and wiring were used and installed correctly. Those with the DHP, how often do you use the winch and how well does it hold up? Thanks guys!
The deep cycle batteries have plenty of power to start the vehicle but also the added benefit of resiliency to charge and discharge cycles.
#34
#35
Originally Posted by Scrambled
It should still be under warranty. I'd try returning it for a new one. Sounds defective.
