Need Ideas for Rear Mounted Lights...
Old 01-12-2012, 04:27 PM
  #41
JK-Ford's Avatar
Looks good man!
Old 01-12-2012, 04:56 PM
  #42
Phantasm's Avatar
THanks,
I did a more extensive write up and credited your wiring schematic and link back to this thread, thank you for that, it was just what I needed. I like simple smart control circuits.
Old 01-26-2012, 03:23 PM
  #43
Tycho's Avatar
Here is my setup. Iidependently switched, works good. LED floodlight.
Old 01-29-2012, 03:49 PM
  #44
DGriz's Avatar
Here's where I just put mine. I need a little more wire to get my switch hooked up but I've got the relay all done behind the rear tail light so it will come on when I'm backing up as well as when I hit the switch.
I removed the tire, took out the 4 screws on the back of the third brake light casing, drilled a hole in the top and mounted the light. I used a plastic washer so hopefully it will stay water tight.
Name:	Real Light.jpg
Quick Reply: Need Ideas for Rear Mounted Lights...
