Need Help for wiring-up backup lights
Can someone tell me if you have installed fog lts. as backup lights?
I purchased these small halogen fogs 2"x2" and want
to install them on my tire carrier and wire them to the backup light.
I do not understand if I need to run a separate power
wire from the battery to make these work without the
supplied switch?
Sorry for my ignorance, I am not an electrician.
supplied switch?
Eternal ***erator
That's the way it looks to me.
although personally, i would switch them as i would like to have the control of being able to turn them on, for whatever reason, without needing to be in reverse.
Eternal ***erator
Yup. I don't foresee a problem with tapping the reverse lights for low wattage reverse bulbs. The diagram shows you that you can hook them up so that you can turn them on without having to put the jeep in reverse. And, yes, fuses are good.
Can someone please help explain exactly how to wireup backup lights through a relay to an off/on/off switch? I see the diagrams above but just dont quite understand them, sorry for my ignorance I am not electrically inclined.
