Need help with the door locks
My 07 Sahara's door locks are going nuts.
Sometime ago the driver door stopped unlocking at the first press on the remote. Meaning that all doors would unlock at the same time instead of the driver unlocking on first remote press and all others at the second remote press.
I did not care much about it since it did not make much of a difference.
However, all of a sudden the driver door is no longer unlocking electrically. I have to use the key to unlock it. All other doors unlock normally.
However, all doors lock either using the remote or automatically when I start driving my Jeep. So, they are still behaving normally as far as the locking expected behavior.
Any hints on what could be happening? Poltergeists?
Thanks in advance!
Thanks in advance!
Not sure about on a JK but we had a 2 VW Jetta that would start off with the same symptoms you are having just before the door lock actuators would die. I would start off by checking your wiring to the actuator in the drivers door. Once I traced this problem to the wires coming just lose enough to not make complete contact with lock assembly.
Thanks! I looked around today and did not see anything loose.
Could be the software?
A while back my Jeep stopped locking the doors automatically when I started driving it. A forum member posted a sequence of stuff to do that made it work again.
Wondering if there's another sequence for the unlocking part.
The driver door is working again, by itself.
Still not doing the two-stage opening thing (first remote press open only driver, second opens the other three doors).
Could not find any loose connection.
A new weird behavior is sometimes the four doors automatically unlocking when I turn the engine off.
Gremlins?
Gremlins?
My 07 Sahara's door locks are going nuts. Sometime ago the driver door stopped unlocking at the first press on the remote. Meaning that all doors would unlock at the same time instead of the driver unlocking on first remote press and all others at the second remote press. I did not care much about it since it did not make much of a difference. However, all of a sudden the driver door is no longer unlocking electrically. I have to use the key to unlock it. All other doors unlock normally. However, all doors lock either using the remote or automatically when I start driving my Jeep. So, they are still behaving normally as far as the locking expected behavior. Any hints on what could be happening? Poltergeists? Thanks in advance!
My remote start stopped working as well as traction control. Dealer said something was wrong with the rear indicator also. Un related but every now and then when I turn on my left blinker the windshield wipers make a single pass.
Thanks! I'll check it out. I changed the two indicator incandescent bulbs by LEDs and at the time the only difference was they blinking faster but nothing else changed. This was a couple months ago.
I'll put the incandescent back and see what happens. Weird stuff indeed.
Just to give an update. The driver door's electric lock is working again. Somehow it was affected by the position/blink LED bulb. I swapped the incandescents back and after a couple miles drive things started working again.
At least partially. The part where the driver door unlocks first is still not working. All doors unlock at the same time.
I'll probably take my Jeep to the dealer and ask them the reflash the computer.
Thanks for the inputs!
What ended up happening? I had this issue of locking while driving. So I unplugged the passenger door and it's not doing it. Should I swap the wire harness or just the lock button. I noticed this because my defrost mirror wouldn't work at times for that door. Sounds like a short...
