need fuse help!!!!!
Old 01-02-2011 | 09:10 AM
robmayas's Avatar
Default need fuse help!!!!!
okay so my wipers,high beams,foglights,blinkers dont work...... i cant find which fuse it is all the mini's look okay.any info for me
Old 01-02-2011 | 09:38 AM
mkjeep's Avatar
Have you tried pulling the codes?
Have you tried disconnecting the battery and re-setting the computer.
Old 01-02-2011 | 10:54 PM
BoggerSwap's Avatar
Check the list under the lid on the fusebox (TIPM). J20 is the wipers. Could also try resting each fuse with a little prong tester thing, or a trouble light (BOTH pins on top should work). HIH
Old 01-03-2011 | 03:47 PM
pcarpenter's Avatar
Check out this link ... diagram of fuse box with descriptions
https://www.jk-forum.com/forums/show...se+box+diagram
