Navigation head unit
Wife just got a 13 Sahara unlimited, without nav. I know someone who has a nav head unit, I shouldn't have to worry about fit issues should I? It's the same size opening in the dash right?
It depends which nav unit you are talking about. It has to be a high speed CAN unit. It most likely has to be a 430N or 730N. You will need to add Uconnect if the jeep doesn't already have it and you are installing a 430N. The 730N has it built in. You will most likely need a microphone too. You will also need the nav/Satelite antenna.
