Mygig the X?
Mygig the X?
Ok, trying to get my ducks in a row for the mygig and I've been doing some searching but still have some questions.
I saw that the 6CD is a plug and play, what about the single?
There are two versions of mygig, high and low speed, whats the diffrence?
I know I need a GPS antenna, anything else besides the recommendations of lock pick?
Thanks for the help.
I removed a 6 disk REQ and installed a RER mygig with nav, You will need to know if your jeep is hi or low speed can bus, I know the 08's are high speed not sure on 07's the RER was plug and play need to install a nav antenna and a Sirius antenna. Here's a link with lot's of info hope this helps.
http://www.wkjeeps.com/wk_nav_2.htm
