MYGIG, Where am I?
MYGIG, Where am I?
Is there a way to reset the nav portion of the MYGIG or MYGIG in general? Recently I have selected the "where am I now" button, and althogh I know where I am, The navigation does not. It has me driving through rivers, RR tracks , unmarked roads. Hey wait a minute is it giving me shortest time travel? it is a Jeep right? LOL. But honestly at times it has no idea where I am. BTW the latest released firmware and not that it applies gracenotes is loaded. Thanks in advance.
Mine does this from time to time. Try turning off your jeep for a little bit then try it again. It SHOULD reset. If not I am not sure what to tell ya
Hope that helps
Hope that helps
Just some things try.
Just the wire get crimped somehow?
To the OP, sounds like either your gps ant is on it's way out, or there is a loose connection behind your radio. Did you install a lockpick? If so, you may want to pull the radio and make sure all the plugs are snug, and not pulling on anything.
antenna
Doh, your antenna went bad?
Frank.
YES IT WOULD HAVE BEEN COVERED... But I didn't want to have to deal with the dealership. Honestly they are a PITA they want to do hours of research and then replace all kinds of other things that "they" think is wrong with it first. (I bet they would have tried reflashing the MYGIG and then replace the MYGIG first before going to the antenna)
So, I purchased it online for $40 total and it arrived at my door and I installed it in 20 min flat. Best part is I didn't have to bring it in during a week day when I work. (They seam to think no one else works M-F from 8-5 but them) No gas used, no hassle, fixed right the first time. Maybe I need to open my own shop...
2 antennas
software update (sent me backwards BTW)
finally the MyGIG itself (finally!)
and they wonder why we don't give them good survey results...
