MyGig, Uconnect question - how to disconnect your phone?
The latest update info is posted here:
https://www.jk-forum.com/forums/show...-Phone-Fix!%29
I know there have been some updates released which fixed phone specific issues on the MyGig. You should check to see if you have the latest updates for your MyGig.
Yes, I think we both have the same issue: if I'm on a call and turn the Jeep off, the radio stays on, and phone call still goes through the radio and not switching to my phone. Very strange, the jeep is completely off and keys outside of the ignition, yet, radio still stay connected to the phone.
What phone do you use to connect?
I figure its just a reminder that you're on the phone still...
Just don't hit the U-Connect button, as it will hang up the call... (did that a time or two)... which is why I found the "switch to handset" feature on the phone!
Yeah, try that "Transfer Call" voice command. I find that's a pretty useful command, because often I will get a call and someone else is in the car with me and I don't want to bother them with the conversation I'm having, so I'll use the "Transfer call" voice command so that it transfers my call to just the handset. You can even use that command to reconnect it back to the radio.
My 2013 does the same thing with my iPhone 4S. I have even set the auxiliary power to turn off as soon as I shut the engine off, but if I have my phone hooked up it still stays on. Even after I transfer my call to my phone, the uconnect still stays on. Quite annoying. I have had other cars with bluetooth technology and never had this happen. Oh well, ill have to try the "transfer call".
