Mygig rhr lock pick v.5
Ok guys I have an 09 wrangler x. Just installed the mygig w lock pick and my reverse camera works but navigation and DVD does no play unless stopped position ??
when my lockpick wouldnt bring up the "view video" button all i did was disconnect the battery for a minute and reconnect it and the lock pick worked as advertised. but as far as the nav goes, i believe there is a setting to turn the nav on and off? i believe one of the dip switches (1-5) not the (1-12)
Ok so I dislocated the battery and then started and it worked fine but once I move off the video it goes back to only being able to watch in stop motion
That is how it works though, it takes practice. Took me a while to get the hang of it with mine. I would push the power once to turn off the unit, then wait a couple seconds and press it twice at fast speed (not super fast, just normal mouse double click speed) to turn it back on. Once I did that, the nav would show my speed as 0 which tricked the unit into allowing me to use the options "in motion".
