MyGig RER Time out / Power off - No doors
Is there any way to adjust how long the radio stays on after you pull the key and walk away?
I had an RBZ in my X and it stayed on for about 30 seconds. I traded in for a Rubicon that has the RER (patched to current) and it stays on for at least 3 minutes after you pull the key out.
Is there a setting in it somewhere that would allow me to adjust it to a shorter time?
Thanks
Thanks
Glad to know someone else is having the "problem". My buddies RER stays on for a minute or less. That tells me something can be adjusted somewhere.
well it's just annoying to be enjoying the music with the doors off, and then stop somewhere, and forget to turn the radio off as you're getting out because you don't normally have to...and then feel like an idiot cause your radio is still going while your engine is off and you're half-way outta the Jeep....
Sam
Sam
Thanks
Thanks
