Mygig REN hdd repair/upgrade
Bought a mygig REN off a guy in my jeep club, he told me it worked which it does however the hard drive is shot. Not upset though being he said he'd take it back with out any issue. Before I hand it back over and get a refund I'd like to try and fix it and keep it. The symptoms it's showing is 0.0 hdd and 0.0 capacity and when trying to play a cd it shuts down. Radio works fine though. Searching for mygig hard drives online came up with one place and they want $225 for it. Other option is to upgrade the hdd to a ssd with the same or a bit larger capacity. With that being said I need some help from members who have done it and are willing to help me out. Or anyone know where I can get a usable hdd for cheap?
Thanks
Brian
Thanks
Brian
When I bought my used MyGIG REN .. first thing I did was buy a $15 Laptop drive off eBay and copy the factory HDD to the eBay HDD. I installed the eBay HDD in my Radio and have the factory original tucked away safe and sound in case I ever need to copy it again. If the HDD crashes I may go with an SSD .. they cost around $50. You must use a PATA 2.5 drive .. not a SATA drive.
Without an original HDD to copy you are kinda screwed. you will also need two 2.5 PATA to USB HDD cases and a program called G4U to do the copy.
Internal PATA / IDE Solid State Drives at TigerDirect.com
Dont know if it will work 100% but it is PATA
Then all you will need is a hard drive image off of a working Mygig and the cable for the hdd to transfer the image off the working hdd to the new hdd via a computer
Maybe too late to reply . .
I read a bunch of forums about guys trying make their drives larger and some started with SSD's when they , one guy said he made an SSD work, but most say they tried and didn't work. Theres a web site I found when I was trying to see if I could make my drive bigger. They said no after trying a few.
MyGig Music has gone Missing, MyGig RER & REN Hard Drive Help
It looks like they provide (sell) loaded hard drives and disk images for download for MyGig RER and REN. They don't tell you how to make a MyGig drive larger, they just send you an image that will do it if you have a larger drive to burn it to.
