Mygig question
I think it's in the main menu (where settings are) near the bottom of the list. I'll be more specific you still can't find it. I'll be in the jeep later tonight and check.
While you are on the Nav screen hit the menu button.
Then hit the Map Items button.
Next hit the Select POI Icons button.
This will allow you to choose what POIs you want to be shown on the map.
Since you have a 2011, I assumed you wanted the new feature that shows you all the closest gas stations along with prices. It's a new function of Sirius Travel Link. POI icons is something different.
Wife drives 2010. Had intermittent problems since day one. Did the update to software at dealer now everything works perfect. Check your software version in system screen and look online to see if it is newest. Do not update yourself. If done wrong whole unit is garbage and will need replaced$$$$
