Mygig Lockpick Navigation Frozen
Installed the mygig lockpick on my 2012 JK yesterday. Everything unlocked (video in motion, text entry in motion), however, I've got a huge problem with the nav. The map that displays my current location is frozen on one spot. As I turn the map rotates as it would normally, but the map never changes. Lets say, I'm at point *A*, as I go down the road the map will rotate around point *A* as my general cardinal direction changes, however the map does not move with me. It's showing my Jeep as being in one location, just spinning around as I change direction.
The only thing I can think of that I've done incorrectly is the switches on the lockpick unit. The instructions indicate that if I have a "High Speed" unit switches 1 and 2 should be in the down position. On the next page is says if I have a "High Speed" Unit, switches 2 and 3 should be in the down position. So naturally, I have switches 1,2 and 3 down.
Any help?
Any help?
I assume that's a plug in the back of the unit. I'll take a look tonight.
I debugged the Nav which mashes the map move but it has me about a quarter mile behing my actual local, and to the left.
GPS antenna is $34 at the dealer. u might have broken the wire. When you turn the lockpick on and off does it change anything? very rarely mine will say I am going backwards. I turn off the lockpick then back on and all is good.
It updates my location every time I turn the jeep off and back on. Then it's been freezing at one spot. I'm going to take a look at the back of the unit and set what the plug situation is. Which is the antenna wire?
short one that goes to the little square antenna above the radio. I think it has a blue plug and the SAT radio one has a yellow plug. I could be wrong on that. Just follow the wire from the antenna over the radio.
