Mygig and Ipod adapter not working together!!??!!
When I ordered my 2009 Rubicon, I got it with all the bells and whistles so it was ready to roll right from the dealership. I did get the Mygig with the added mic and Ipod adapter. It was only reciently that I did plug in an IPod and then realized that it does not work. I brought it back to the dealership and told them about this issue. They told me that the IPod adapter came with the mic (so it was free) and only certain Mygig unit can utilize the IPod adapter. So, they tell me that there is nothing more that they can do for me. Has anyone else heard of such a thing? That makes no sense on why Chrysler would do that and it looks like my unit should accept that as the screen does have the aux "soft button". Just wondering what recourse I may have...
When you say it doesn't work, what do you mean? No functionality at all or it doesn't work correctly? There appears to be a bug in the 4.0 release of software for the iTouch such that it doesn't work CORRECTLY with the iPod cable at least with the RES radio, and maybe yours? If you have an iTouch with 3.1.3 (or earlier?) software, that's not the problem.
sd
sd
Ultrasport an I have been through this a little bit.
My IPhone wasn't 'seen' by the system using the normal white Apple USB connector. When I switched to an aftermarket cable that uses the earbud port, it worked just fine.
With the IPod connector I can only charge the device. I can not get music or control it through my radio. I have tried several different IPods out there to the same effect, no music and no ability to control it...
There is a possibility you have one of the very early 2009 MyGigs. I can't recall the part number for them, but I had one and it would not work. I sold it and got a later 2009 and it was fine.
Have you checked the connection in the back of the mygig to make sure everything is plugged in properly. I'm sure you have, but if not I'd start there.
So if I asked for that option and they supplied me the Ipod connector without the proper radio, are they on the hook to supply me with the proper unit? When I first picked up the vehicle I did not have an Ipod so I was not able to ensure that this option was working, can I make a valid claim to get the currnet head unit?
