mygig and amp
mygig and amp
My audio installer tried to get a clean signal from between the mygig and Infinity amp, with no success using CHYAA07 . First time he tried it worked for 5 min, then the system went to full volume. he thought he blew the part somehow, so he ordered another one, and it did the same thing.
so now I got a 1000watt amp and 15" sub connected by taking a signal from the front speakers, and it sounds horrible, my installer says there is no solution. Can anybody help me!! please!
I just tapped the rear OEM subwoofer speaker wires and run into my amp via a line level converter. Worked fine for me, but I'm not running a 1000 watt amp either (just a 250 watt amp powering a 10" bazooka.)
I was just thinking to myself . . . . lockpic has rca outputs, if I add a lockpik will I get the clean uncrossed over, un ampliphied signal i'm looking for?
Good Luck,,, I tried the converter with the rear sub wires and could not get it to work. As of now, I am thinking of just pulling the entire stock system out. And putting in exactly what I want.
Same here works and sounds great this also takes alot of stress off the stock infinity amp and my others speakers sound so much cleaner.
