My Wiring Plan (Switches, Relays, Ect) - What do you think?
XXXhttp://www.offroaders.com/tech/12-volt-wire-gauge-amps.htm
If that chart is right, the harness that came with my kc lights is way to skimpy. I'm pretty sure its a 18 ga, which if i was doing it myself would never have used, but figure they arent going to produce a dangerous product.
can you post or send pics........i am about to start my wiring and was looking for a neat way to store the relays...not finding much....any suggestions will help.....I will need about 4 relays for now, but would like room for expansion.
Edit: oops, you mean the backup lights that only draw 1.25 amps. You don't need a relay for that.
I'm changing this plan thanks to some of the comments, backup light and backup camera/monitor are going to be switch driven with no relay. I should be well under my total amp draw allowed.
This guage chart seems really heavy. I've been using this one:
RE: the OP's original diagram: may be a stupid question, but what is the guage [sic] shown at the very right side, coming from the fuse box, for? Nice work, thx for sharing.
Ok, here's my re-worked diagram, this layout makes it a lot easier for me to visualize the load on each wire. I have to confirm every wire length and amp amount I have on here still, but I think its goanna be overkill which is better than problems.
bookmarked for future use!!!
