my gig locked
my gig locked
I have recently purchased a my gig radio on eBay. The problem is when I plug it in it asks for a four digit security code. The seller has sent me a few different codes. None of which work. Is there any way to crack it or should I just try to get refunded.
I also believe that the security code is tied to the VIN of the vehicle the security code was set in. So that's why the security code sent to you, won't work when the MyGig is installed in your vehicle.
Take it to the stealership. they can program it, unless it is stolen. in that case, take it to the police department and have them run the serial #. If it pops in NCIC as stolen, contact eBay or Paypal if you used them to pay. I would be really hesitant to buy a used MyGig just based on my experiences with new ones sucking balls....
http://www.wkjeeps.com/MyGIG_parts.htm
Forget the three letters. What exact part number is it? There are a ton of "mygigs" out there for two different bus system speeds (High and Low)
The below examples are for "RER" units only
I.E:
P/N 82211473
P/N 82211473AB
P/N 82211473AC
P/N 82211473AD
P/N 82211473AE
2009
P/N 82211860
P/N 82211860AB
2010
P/N 82212009
Only will work on the wrangler
WILL NOT work on wrangler:
2008
P/N 82211471
superseded by:
P/N 82211471AB
P/N 82211471AC
P/N 82211471AD
P/N 82211471AD
2009
P/N 82211859
superseded by:
P/N 82211859AB
2010
P/N 82212008
I.E:
P/N 82211473
P/N 82211473AB
P/N 82211473AC
P/N 82211473AD
P/N 82211473AE
2009
P/N 82211860
P/N 82211860AB
2010
P/N 82212009
2008
P/N 82211471
superseded by:
P/N 82211471AB
P/N 82211471AC
P/N 82211471AD
P/N 82211471AD
2009
P/N 82211859
superseded by:
P/N 82211859AB
2010
P/N 82212008
