MY Gig Help!!!!
MY Gig Help!!!!
So I was hoping to get some advice. I have a 2012 JK that i recently bought a High speed RHR My GIG radio off ebay that said it was working. The install was easy but I quickly noticed a problem right away. It would start to load and a Dodge screen would appear but nothing else would happen. I was wondering if anyone had any thoughts or suggestions. I am not sure if it just needs flashed by the dealer or if it was actually a low speed RHR unit. The only other alternative is that must be broken. I would greatly appreciate any insight into my problem.
Try disconnecting your negative battery cable for a few minutes. Then reconnect the cable and try again.
Its OK if it shows a Dodge splash screen, the Jeep one will replace it automatically.
Sill no luck, The lights for the switches turned on but then they stopped lighting up when i tried to turn it on. Still just tries to boot up but with no luck. Thanks for the advice though
The MyGig does the changing of the Logo, not the Vehicle it is in. The mygig gets a Vin Signal and if not the same next Boot up, it will change. This is proven by by a unit being installed in one too many models of vehicles.
This behavior has turned out to be from installing The Wrong Can Bus speed unit in 90 percent of this fix......
Part number 68092001AC, Man. T00BE199156428
I am pretty sure that it is low speed and I just got screwed. The part Number and the part number that the guy posted on Ebay are completely different. Unbelievable!!!
Here's the OEM sellers:
Dodge Chrysler Jeep DVD CD Sirius 730N Mygig Low Speed RHR GPS Navigation Radio | eBay
DODGE CHRYSLER JEEP DVD CD SIRIUS 730N MYGIG LOW SPEED RHR GPS NAVIGATION RADIO
PLUG & PLAY! -WE OFFER PROGRAMMING & EXTRAS! -WARRANTY!
Seller information
www-oemautopartsco-com
100% Positive feedback
Item specifics
[TABLE]
[TR]
[TD="class: attrLabels"] Condition:[/TD]
[TD] Used: An item that has been used previously. The item may have some signs of cosmetic wear, but is fully ... Read moreabout the condition
[/TD]
[TD="class: attrLabels"] Model:[/TD]
[TD] Factory, OEM[/TD]
[/TR]
[TR]
[TD="class: attrLabels"] Manufacturer Part Number:[/TD]
[TD] 5064821A*, 68092001A*[/TD]
[/TR]
[/TABLE]
Item condition:
Used
Quantity:
8 available / 2 sold
Was:
US $1,440.00
You save:
$144.00 (10%)
Sale ends in 4 days
Price:
US $1,296.00
