mounting lightforce spotties on bullbar
I'm about to go out and buy a set of lightforce 240 xgt halogen spot lights to mount on the front of Rubi and i just wanted to know how everyone else out there has done it. Do i get some tabs welded to the loop in the bar or are there some pipe clamps that would work on the 65 mm tube loop.
I've seen a couple solutions with this. Northridge 4X4 sells tabs you could weld to your bull bar. I've also seen clamps that are designed to clamp on tube steel and provide a mount for lights. Going from memory I believe quadratech sells these. You could also make your own tabs out of flat steel. Would be easy and weld them or take them to a shop to weld them up for you.
I would have welded tabs with anti theft nuts.
Bull
Bull
