Mount winch solenoid on 2012 3.6L under hood
So this project is coming along. Mounted the warn box in the same location as above. One issue I'm dealing with is finding a way to protect the cable where they run under the body, near any metal, anywhere else they may wear through....the 1/0 welding wire is VERY thick and but it's flexibility is making it possible. I'll post pictures once it's all said and done.
Yeah, the Pentastar engine bay is jam-packed with less engine! Doesn't make much sense. There isn't room for anything! I was looking at a buddy's 88 YJ engine compartment yesterday and laughing. You could fit a small apartment in there!
Getting ready to put my winch order.. I going to add a switch in the cabin and now I am going put the solenoid under hood as well and use the stock bumper to mount.
was the 4 gauge the right diameter to maintain the waterproofness(?) of the controller box? Or did you have to end up putting some silicone on there to seal it? Also, is the 4 gauge heavy enough to handle the amp draw?
