Metra XSVI-6522 harness
Old 02-10-2008, 09:57 AM
blockrockin's Avatar
Default Metra XSVI-6522 harness
hi i am trying to get the speed from the vss wire does anyone know if you use the Metra XSVI-6522 harness ,will that give you a wire for the vss that you can use ? thanks alote .
Old 02-17-2008, 04:40 AM
anyone here use the Metra XSVI 6522 harness ? i just need to know if it has a vss wire ? ive been looking and looking can seem to find the answer? i know the PAC C2R-CHY2 does but its twice the price and all i need is the vss wire. i just want to make sure it has the vss wire before i buy it . thanks for the help !
Old 02-17-2008, 05:16 AM
KCTW's Avatar
I'm sorry I can't give you an answer, but what is a vss?
Old 02-17-2008, 05:44 AM
vehicle speed sensor . its for navigation it sends the speed of the jeep to the nav unit to help be more accurate .
Old 02-17-2008, 08:46 AM
JackMac4's Avatar
the 6522 does not provide a VSS wire. You have to get the CHTO-03 in order to have a VSS wire. The VSS is integrated into CANBUS, so there isn't actually a VSS wire - which is why the CHTO-03 provides one.
Old 02-17-2008, 08:48 AM
great ! thank you . just what i needed to know !
Old 02-17-2008, 09:10 AM
JackMac4's Avatar
No problem. PAC makes a similar adapter as the CHTO-03, but I haven't seen anyone use it yet.
Old 03-09-2008, 09:19 AM
2K1TJ's Avatar
Bumping this back up.
Did you ever find a way to get the VSS signal? I bought this harness (XSVI-6522 ) because that's what I read that I needed if I didn't have the Infinity system.
am I screwed?
Old 03-09-2008, 09:22 AM
Yamaha90's Avatar
yeah you might be, looks like i'll get this harness when i get my D3 i hate bad directions
Old 03-13-2008, 09:59 PM
RonFDNY77's Avatar
i have the 6522 installed with my kenwood dnx7100 works great, evry accurate with the speed, the vss wire from the nav unit get grounded to disable saftey feat. i think there is a second wire for speed on the unit but i dont really know my friend installed but i do know that if u have any ? u can call metra or crutchfield
Quick Reply: Metra XSVI-6522 harness
