Low tire pressure light,
Just changed my tires and my low pressure light keeps coming bk on since my rims prob dont have chips in them, is there a way to remove that light?
The lowest common denominator at AutoZone is not going to remove sensors from your wheels or add them. Furthermore, they don't have the scanner to turn that safety feature off. There's not a quick bulb you can pull either to turn out the light.
Correct me if I'm wrong.
Sent from my GT-P5113 using Tapatalk 4
The lowest common denominator at AutoZone is not going to remove sensors from your wheels or add them. Furthermore, they don't have the scanner to turn that safety feature off. There's not a quick bulb you can pull either to turn out the light. Correct me if I'm wrong. Sent from my GT-P5113 using Tapatalk 4
I know because they do it to mine. I run 37s at a lower psi and the light goes on every now and then. Take it to auto zone and they reprogram the jeeps computer to have the light go off...
