Looking to rewire rubicon lockers to spod
#21
I don't use an sPod, rather have my own fuse block w/relays that I wired myself. BUT, the below diagrams may help you. Plug 1 (the small plug) is the locker. Plug 2 (larger) is the actuator/indicator.
I don't like the computer controlled locker stuff so I bypassed it completely. One thing missing is that I also wired in a safety switch so that I can't inadvertently activate the lockers, just a small round rocker switch that has to be turned on in order for the OTRATTW switches to get power. So, the small rocker switch feeds 12V positive to spades 2 and 6.
The way I have these wired, the large LED window comes on when I activate the switch, then the small horizontal LED comes on when the lockers actually engage.
Attachment 631706Attachment 631707
How does that position sensor work? The light should come on when the locker is fully engaged, correct? Is there any blinking or other indication besides not lighting up? If so, how is that controlled?
