long range lights connection HELP
Hi guys!
I was wondering if it's possible to connect my long range Hella lights to the stock long range light switch (I don't know what's it called in English, but it's the switch on the left side of the steering wheel which you have to flick forward to turn on the lights). I already have an extra switch for the Hella lights and separate wires, but i'd like for all the long range lights to be on the same switch. Can it be done? I don'd know if I explained correctly, but I hope you understood me.
Thanks in advance
Thanks in advance
Hi guys!
Thanks in advance
Thanks in advance
Yes, you can just tap into the high beam wire near one of your headlights to energize the relay for your Hella's.
I cannot say about the newer ones. I had 4 on my 07 that worked flawlessly. Unless they changed them in the newer models it shouldn't be an issue. I ordered a set of KC's so I hope it still works.
I would highly recommend keeping the KCs on a separate circuit. Not sure which KC lights your running, some draw more current than others (unless using a relay). Also, I cant say for certain limitations are on the stock circuit for the high beams...you may run into problems energizing both KC and high beams together (if tapping the circuit without a relay).
