Locker/swaybar switch wiring for switch backlight
I'm wiring up a switch for my ARB air compressor. I'm looking for wires to link into for the lighting of the switch. Closest one I can find is for the switch panel for the sway bar/
Locker. There's three wires, trying to figure out which wire as for the lockers, which wire is for the sway bar, and which wire is the power for the switch lights. I want to tap into the power wire for the dimmable lights on the switch. I've tried poking around with a test wire but not having much luck. Would prefer not to pierce the wiring if I don't have to. Anyone know which wire is which?
Heya Rubichronic -
I thought I recognized the forum handle from the BC Jeep Club - it's me ... you know, ME - Neville with the 2016 Anniversary Ed. Jk !!
Hah, hah - small world ...
Neville
Neville
Those are low voltage wires that work thru the can bus, I would not tap into them. I believe the cig lighter next to that switch is keyed to the ignition.
