Lights on XHD Bumper??
Old 04-08-2012, 04:05 PM
Raisinhead's Avatar
Default Lights on XHD Bumper??
I wanted to see what kind of light setups people have installed on their Rugged Ridge XHD bumpers. I'm leaning towards doing an 8" rigid industries light bar somewhere.
Pics or ideas welcomed!!
Old 04-08-2012, 04:14 PM
truckie515's Avatar
This what I did with mine just use the bolt that you have on the loop or you might get some just a hair longer
Old 04-08-2012, 04:21 PM
Matthewd5's Avatar
are the holes in your bumper the same size as the factory fog lights?
if they are you can most likely use the BDF bracket and put some rigid dually 1's or 2's into those holes
matthew
Old 04-08-2012, 04:31 PM
oriffx's Avatar
Here you go....
Old 04-08-2012, 05:11 PM
Raisinhead's Avatar
matthew
They are, but they won't come out without taking off the bumper. (which is really annoying). I am planning to also do those brackets eventually though. Thanks
Old 04-08-2012, 05:15 PM
Matthewd5's Avatar
removing the fog lights from the factory bumper nearly required carnival side show flexibility!
nice looking jeeps guys/gals
mine is still 99% stock
been focusing on lighting first and then i'm putting a set of evo skid plates underneath and then onto better tires
matthew
Old 04-08-2012, 05:28 PM
Raisinhead's Avatar
Originally Posted by truckie515
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=301370"/>
Not a bad idea, just not sure if it would look right or fit being so close to the loop.
Is there anything wrong with mounting it to my roller fairlead?
Old 04-08-2012, 10:43 PM
Sapper12b's Avatar
I have the XHD bumper and Im going to install a 10" Rigid light bar on the hoop. Ive discovered the Rugged Ridge used a very large diameter tubing when making the hoop, its about 2.36 inches in diameter. Since the hoop is a larger than normal diameter I've found it difficult to locate the correct mounting clamps that will fit. Luckily one of the sponsored vendors ,Alternative Offroad, carries the correct mounting clamps tofit the hoop.Ill take some pictures when i mount my light this week.
Old 04-09-2012, 03:57 AM
Raisinhead's Avatar
Sweet, please post pics once you do!!
Old 04-12-2012, 01:19 PM
Sponsoring Advertiser
DriveOffroad's Avatar
Here are a few I had lying around of some shop vehicles.
Quick Reply: Lights on XHD Bumper??
