Lights dim
Old 03-01-2013 | 07:21 AM
Thumper291's Avatar
Default Lights dim
When I back out of my driveway and cut the wheel to the right, the turn to the left when my wheels straighten out my lights dime. Does this happen to any of you
Old 03-01-2013 | 08:01 AM
C2U5H's Avatar
If it's really cold and it's right after you start your Jeep, it could be the power steering pump working really hard to move that thick steering fluid. Would put more load on the engine and perhaps slow down the alternator a bit. You can usually see this happen if you turned it to full lock and kept trying to turn more, too, to verify. That's the only thing I can think of. It's not a problem and is pretty normal for vehicles I've owned.
Old 03-01-2013 | 09:48 AM
JK-Ford's Avatar
Good Call.
