light wiring
light wiring
i am wiring up a second set of ipf lights. my questions are as followed.
can i use the one switch for both set of lights, just jump off the switch wire?
the set that i have on now is jumped off my high beam wire, can i jump the second set off the wire that is attached to the high beam wire? everything else would have its own relay, fuses, and power wires
please advise
please advise
Scootersjk
light wiring
light wiring
FYI; You can make the trigger jumpers at the relay. You do not have to run a second wire back to the switch or the high beam circuit.
i also have a few questions;
im going to be installing the mbrp light rack (above windshield) and will be adding 5 more 6" KC daylighters
-i already have two 8" KC's and two 6" KC's
--am i going to need to run dual batteries or will i be fine just hooking them up to a fuse?
