Light mod need helps
So I'm putting in some interior lights and I already have a power source and ground planned, but I'm not sure how to wire in a switch turn turn the lights on as I wish. I wiring schematic or a detailed explanination would be appreciated. Thanks in advance for your help.
In my JK I don't have lights that are connected to both so I've never wired it that way. There is a thread on rock lights that show how to wire using a diode which allows you to use a switch and the dome light. Check it out
https://www.jk-forum.com/forums/show...sy+rock+lights
Double Throw/Double Pole switch. You would connect both outputs together to the light. On one side use a tap from the dome light to power it. On the other side connect to a constant hot or ignition switched power osurce. Position one: Does what the dome light does. Off is off.. Position two: On and Off with the key or always on depending on power source.
I splicing a light source into a wire that is hooked to the dimmer switch(+) and a ground wire(-). I just don't understand how to hook up the (+) (-) to the switch. I have a three prong switch •-earth (ground I'm guessing)
•-LED (lights positive prong?)
•-supply (positive wire splice)
Any ideas, comments or questions?
Earlier reply was to MontaukRubi.
RED_RUBI_07: The wiring you asked about looks right. If the switch does not light up, swap the SUPPLY and LED wires. If you are unsure just do not connect GROUND to the switch. That will only prevent the switch from ever lighting up. The lights (Load) should work though.
couldn't you just wire in the switch parallel to the dome dimmer?
Thinking about it, that would just bypass the dimmer, and when you hit the switch it would turn the dome light on as well.
That's why I suggested and used a DPDT switch. One side uses the dome/dimmer as a source. The other side uses a constant or ignition switched as a source.
I agree w/vernnz...I believe his solution would be the simplest and would accomplish what you want. doesnt sound like the switch you have is double pole/double throw (DPDT)
