LED Light Strip ???
LED Light Strip ???
I am looking into placing some LED light strips inside my two door. I noticed on some of the led strips you can cut a desired length (every 3 leds etc.). My question is after you cut the excess off, can you wire the left over and use it somewhere else?
This way, I would only have to buy one longer strip and cut it into pieces. Rather than two or three short ones.
Thanks!
Thanks!
I am looking into placing some LED light strips inside my two door. I noticed on some of the led strips you can cut a desired length (every 3 leds etc.). My question is after you cut the excess off, can you wire the left over and use it somewhere else? This way, I would only have to buy one longer strip and cut it into pieces. Rather than two or three short ones. Thanks!
Thanks for the response! Do you have any pics of your under hood lights? That was an idea I had also.
https://www.superbrightleds.com/more...gn-module/944/
I also used some multicolor ones in my poison spider vent too.. cause why not
I don't have the best photos.. But i used a version of these: https://www.superbrightleds.com/more...gn-module/944/ I also used some multicolor ones in my poison spider vent too.. cause why not <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=618230"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=618231"/>
so, I have an aftermarket alarm that has a hood pin that goes to ground when the hood is opened. I tapped that ground for the negative side of the led so the lights come on. The hood pin switch is like 5 bucks on Amazon
