LED light bar for inside mounting...?
Ever plan on spot welding the 8 torx bolts ( 4 on each side) that mount onto the A and B pillars where the light bar mounts? I plan on doing that eventually so if the thieves wanted the light bar, they would have to grind off the welds. It will take them longer to steal and most likely draw attention preventing them from removing the light bar. If you ever need to remove the light bar, you would have to grind them also but I think that its a good idea to prevent theft. Great way to preserve your investment.
Imagine parking in a hot desert, with no wind. OR in a small garage. You can still use every light on your Jeep as long as you want, without overheating them (That is of course if you have not installed anything extreme that requires air flow to keep cool...).
And there are ways to decrease heat development in the LED housing without using fans.
I contacted my suppliers in China, and they are looking into it. I might have them make me a prototype, to check how it works.
And there is room in the Jeep for this. I am 6' tall, and sitting in the front seat, a 1 1/4" inch thick light bar will not make a difference to my view of the road. There is plenty of room for 2 x 12-15 inch light bars, with a single row LED's. And they can be easily bolted straight on.
Spot's will not give much glare, but flood's will, unless the LED's can be retracted a little bit into the housing.
To me, this would be the perfect solution. But for others, it would make no sense..
If this is made right, heat will not be an issue. I have been developing electronics for a few years, and LED's (depending on how powerful they are), are not very hot. You will not be able to have EXTREME power inside the windshield, but most light bars can handle this.
heat could be an issue, if the light is used for any extended periods of time it will get warm. I know they don't get as hot as other types of lights but the housings still get warm. Just because it works in extremely hot desert type conditions doesn't necessarily mean that you want a heated light bar across the top of your windshield. I have various led light fixtures from ones on my jeep to fish tank lights and they all vary in running temps. I have some that warm up enough that you can't touch them without a cool off period. I think some testing should be done before just assuming that they won't create too much heat inside the vehicle.
If you ever see a bald guy driving a black JKUR in SoCal with fire damage to the freedom panels, you will know that the prototypes did not work as planned...
But please do keep us updated on how the testing turns out
Most likely I will have multiple samples of different sizes for inside and outside... Looking into this industry with help from my Chinese team, tells me these product might be very overpriced in the US...., and still with a lot of development potential.
I have developed and sold computer accessories in the US and Europe for many years, and after buying my JK, I see an opportunity here.
I might develop a full product line with all kind of lights. Any ideas for lights that would be interesting to develop, PM me, and I will send it to my team in China for development quotes. I am already looking into a high power CREE LED for mounting flush into the grill with up to 4000 Lumens, without causing less cooling for the radiator.
Google came up with this
911Lights.com - Interior Lightbars
Signal Vehicle Products Starburst Dash-mount Lightbar, 6" w/ 6-LED Array Unit, Suction-cup Front Mounts & Cigarette Plug DL156 | $5 Shipping Sitewide!
I have to admit had never even thought of anything inside the windshield ....that is something that someone should design albeit ..they would have to make it sit right against the windshield for glare reasons...maybe with a shock proof rubber lip that sits between the two.
What is the purpose of this lightbar, is it for warning or for area/driving lights?
