Led headlight harness question
Guys,
Got a set of eBay led headlights that are a knock off of JW's.
They came with the h13 to h4 adapter and antiflicker module.
Question is, I tried to see if they would flicker without the module between the adapter but they wouldn't work at all without the antiflicker installed.
I thought you were able to just plug the adapter in and they'd work but maybe flicker.
These won't come on without the antiflicker installed. Is this typical?
One headlight wouldn't come off of high beam without disconnecting completely.
Sent back and got real Trucklites
Sent from my SM-N920T using JK-Forum
I bought a brand called Lantsun, it's Chinese I believe. $188 for the pair with LED halos that are white DRL's and turn Amber with your turn signal. Pretty easy installation, plus saved me a boatload of money.
You made the right choice with the truck lites. Spend a little more once. The cheap ebay/Chinese stuff is cheap for a reason. Poorly made, Poor design, poor light spread, beam, pattern etc. Do it right. There are other places to spend less money.
Haven't fully adjusted them yet. Did a quick set up but my driveway is angled upward about 5* so couldn't get an accurate read. No night pics yet but here's a shot of them in the Jeep <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=636864"/> Sent from my SM-N920T using JK-Forum
The x in the truck lite is from the led mount. Yes I have it, I only notice it when I am against a wall or pulling behind someone at a stop sign etc. While driving I don't even see them. Once Highs are on you don't see them either ha ha.
