Led footwell lighting.
#41
Great mod, I used blue on the floor stick on under the center console but opted for the red strips to light up the shifters. I used clean power and seperate switch, night runs big plus also added a flexable map light.
I also am looking for a door pin switch for the center console box, I found some great LED bolt type lights for the lisc plate which should stay protected and look good in this application too.
#42
#43
Hi sringer, neat idea. i'd like to try it and i've got some leds i bought off of ebay. i'm not an electrical guy but think this is a mod worth exploring.
what size wire did you run to and from the led strips?
did your led strips have some sort of built in resistors?
one wire goes from the power in the dome light circuitry into the led strip. the other wire goes to...?
sorry. like i said. electrical noob.
#44
#46
#47
Would it be possible to do this mod where the lights are turned on with the dashboard lights? I would like to have them on while my headlights/dash lights are on as well. Is this possible with some simple wiring or would require something more complicated?
#48
#50
