Led footwell lighting.
Old 11-27-2011, 04:47 PM
  #301
sringer's Avatar
Originally Posted by dwebb8355
Nope did it and tried the white with yellow stripe just to make sure. But I'll try again tomorrow to make sure
Hmmm. Good luck
Old 11-28-2011, 02:49 PM
  #302
sringer's Avatar
Originally Posted by drexelpike
few things to check (pls don't take offense to any of this, just covering bases)
1) make sure you have a good ground
2) make sure you have a good connection to your + (yellow with white stripe)
3) make sure you're using LEDs designed for a 12v power source
4) make sure you turn your dome light switch on
This is true. Sometimes it's the little things you miss...
Old 11-28-2011, 02:50 PM
  #303
dwebb8355's Avatar
None takin I actually have a test light but didn't take the time to go through them all but now I'm actually thinking of not doing the footwells and hooking it into the hvac and using it under my radio to shine some light on the cup holders. But I'm not worrying about any of that till this weekend ordered some cowl protectors and they just came in so prolly gonna put those on first
Old 11-28-2011, 03:37 PM
  #304
sringer's Avatar
Well have fun spending quality time with your jeep
Old 02-23-2012, 02:54 PM
  #305
tribangle's Avatar
Anyone do this to a 2012?
Any concerns about tapping into the wire for the dome light?
Old 04-24-2012, 10:40 AM
  #306
jayzbrown's Avatar
I did this to my 2012 JKU, just tapped into the thin yellow wire with white tracer. It's located on the right side of the passenger footwell in the wire cluster(about 25 wires) Bought the lights from Pepboys for $15.00. Very simple and cheap mod!
Old 04-25-2012, 05:40 AM
  #307
MikeTHIS's Avatar
I don't remember if I posted here or not...
I tracked down the correct plugs for the factory footwell lights and put really bright LED's in them and made my own harness.
Old 04-25-2012, 05:48 AM
  #308
HELLBENDER-JK's Avatar
Please explain what you did and where these wires are at in the footwell
Old 04-30-2012, 12:24 PM
  #309
jeeps_187's Avatar
yes, please explain.
Old 04-30-2012, 03:53 PM
  #310
PANGMAN's Avatar
Try switching the wires around for the led strip.
Quick Reply: Led footwell lighting.
