Led footwell lighting.
Old 11-26-2011, 08:48 PM
  #291
Goowa's Avatar
This is an awesome mod!!! I know I may seem like an idiot asking this again, but I'm an electrical moron.
Is the yellow/white strip wire that you're splicing into make the lights dim-able like the dash lights, or is it only on with the dome light?
I have a 2010 Rubicon if that matters. I read on another forum someone talking about an orange/white wire.
What I want is the lights to come on whenever the dash lights would be on, and I want to make sure they dim with the dimmer switch.
Thanks in advance and sorry for the dumb question.
Old 11-26-2011, 09:18 PM
  #292
Goowa's Avatar
Just in case anyone else was wondering, I figured out the answer to this question.
You tap into the HVAC wiring. You can find a write-up HERE
Old 11-26-2011, 09:24 PM
  #293
TURTLECON's Avatar
Orange/grey HVAC dimmable wire
Yellow/white Dome light wire
Old 11-27-2011, 07:41 AM
  #294
sringer's Avatar
Originally Posted by drexelpike
they come on with the dome lights, mine don't dim though, but they must be able to because they fade out just like the dome light though.
i like to ride around with them on, so I ordered a dome light housing from a REAR JKU and put that in my 2dr's sound bar. it looks exactly the same, except you can push the lens to turn it off/on. so now i can turn my dome lights on (which turns on my floor lights) then turn the soundbar's dome light off so that its not too too bright in there..
very easy mod. show pics when ur done!
Wow. Great thought on the rear one. Never thought of that. Pm me a link if you would and post up how you wired it
Old 11-27-2011, 08:18 AM
  #295
tenmile's Avatar
That's a genius idea....
Old 11-27-2011, 09:05 AM
  #296
sringer's Avatar
Yes it is. Please share
Old 11-27-2011, 11:27 AM
  #297
sringer's Avatar
you can read all about it here: https://www.jk-forum.com/forums/show...dome-light-mod.
good luck! (not that you'll need it)
Thanks! Might have to do it
Old 11-27-2011, 03:01 PM
  #298
dwebb8355's Avatar
Need some help with mine I have a 2011 pretty sure the wire is a different color code found out how to wire it where they are on all the time but I just want them on with the dome
Old 11-27-2011, 04:13 PM
  #299
sringer's Avatar
As far as I know it's the same. Make sure you did yellow with white STRIPE not white with yellow stripe. That's most ppls mistake.
I just tapped into it in the dome light.
Old 11-27-2011, 04:15 PM
  #300
dwebb8355's Avatar
Nope did it and tried the white with yellow stripe just to make sure. But I'll try again tomorrow to make sure
Quick Reply: Led footwell lighting.
