Led footwell lighting.
#281
Did the front a while ago then finally got around to doing the back. so much better than those weak a$$ dome lights
Attachment 214446Attachment 214444Attachment 214445Attachment 214447Attachment 214448
#282
So how do you have them wired up ?
#284
#285
Originally Posted by Jhen
I just tapped into the existing dome light wiring + - then branched off for the individual Led's
#286
Attachment 227114Attachment 227115I think 07 was the last year they had that connection. Check it with a tester and your done. They will only light when your dome light comes on though. I keep mine lit red whenever the parking lights come on. Brightens up that dark area nicely.
#287
haha im an 07 jk x and i didnt know about that...guess i did it the hard way. o well. lol
#288
I did the antenna removal mod. Took 30 secs and it looks clean without that stupid silver wire sticking up. Who listens to radio anyways but if you must know the reception still works fine with out it.
#289
#290
Originally Posted by drexelpike
ended up using that courtesy light connector with no problem. just cut the stock connector off and buttspliced to it. easy!
used suitcase clips on the power (yellow w/ white stripe) and clipped into a random wire going to the ground screw.
done and done.
very happy with it. makes a big difference.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=227969"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=227970"/>
