Led footwell lighting.
#211
Just got around to doing mine today. I bought a 10pk of pre-wired orange 5mm LEDs and recepticles. I originally intended to do all 4 vents, 1 above the light switch, 2 above the HVAC controls, and front and rear cup holders. I didn't have enough time to pull the center console, so the cup holders will have to wait.
Turns out the vents are not as bright as I had hoped with one LED per, so I'll need to order more.
I might do footwell lighting later, but for now I just wanted some ambient light on the dash so I could see what I was doing at night
#212
#213
Just to add, to do the vents I used four pre-wired surface mount LED's from Oznium and some wire. I spliced them in to the orange/gray going to the HVAC so they are on whenever the lights are on and are dimmable with the stock controls. I went out at night and played with different mounting locations to get the effect I was looking for. Turned out great and they don't bother you while driving at all. Now all I need to do is swap all the gauge, radio and hvac lights over to blue....
#214
I went with green Attachment 149763
so has anyone had problems with switching their domelight bulb to a colored one and then the colored one not lasting very long and starting to flicker and die?
#216
i put mine in at the beggining of winter....it said it was good for 10,000 hrs...its probably not even been on for two hrs total and its flickering...but its been 6 months or so id say...at least my order came with two bulbs for....$7.98 and free shipping =)
#217
I got rid of the dome light all together and mounted LEDs in the sound bar.
#218
Originally Posted by Jhen
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=154569"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=154570"/>
#220
