Led footwell lighting.
#201
#207
Originally Posted by dgnr8
Can you send me the auction ID or the seller?! I need these!!
#209
Originally Posted by mcdona90
Could someone share where the strips were mounted in the footwells?
Cheers
Cheers
#210
Cheers
Cheers
Originally Posted by Jeep Hound
If you look at my photos posted it shows underneath. If you look under the driver or passenger side you will see a metal strip this is where the lights mount using 3m tape the strip is only about 1/4" wide the style shown in the photo works perfectly in this space. Clean the area with a rubbing alcohol/ water mix, let it dry and stick the light in place
