LED Fog Lights?
#23
#25
I have the VisionX foglight kit. No problems, no flicker on or off. They are extremely bright and cut through the fog like a hot knfe through butter. My only gripe with them is the beam pattern. They do not have a wide enough beam angle (only 35 degree) to serve the purpose of foglights. Although I am very happy with the VisionX they are not wide enough for the UK roads. The roads hear are very narrow and the light does not make it to the sides to see where the road ends or where the other lane(s) are. I would suggest for the actual purpose pf fog lights go with Rigid D2 wide beam and aim it way down on the raod or go with Rigid D or D2 diffused if you are worried about blinding people.
#26
#27
#28
I have a write up in here somewhere. No, they're nothing like the Rigids. About the same intensity as oem fogs but with perfect matching color and lens design as my Trucklite LEDs. They're better used as DRLs than as fogs! Just can't justify the JW Speaker fogs yet.
#29
#30
I have duallys in the bumper with factory wiring and Speaker LED headlights.
