LED fog,flood, and spot lights
I have decided that LED's are the way of the Future. I will wait for the new truck-lites to come out in Jan.
I will use truck lite 7" to replace my stock headlights.
I will use Rigid dually d2's flood on the bumper.
I will use Ridid dually d2's Spot on the windshield.
Here are my thoughts:
1. as stated before LED is the way of the future.
2. LED has a very long life
3. LED's are bright- I wont need factory fog just to drive.
4. LED's are almost indestructable.
5. I dont get off on changing light bulbs (even on a jeep)
6. LED's draw no power, so If I am Winching up in the woods at night I dont have to worry.
7.Cibie,IPF ect can break.
and while I am sure the LED pattern is not a good as other, I am sure it will be good enough for me. Since I hhave little experience, I can only go by what I can glean from forums like this. If my logic is flawed, please enlighten me. Get it? enLIGHTen ---
My only suggestion would be to consider the regular Duallys. It would save you a good chunk of money and still give you more than enough light. But it really sounds like a great plan.
Even when I was driving through white-out conditions at night on Rt. 82 in CO, my fog lamps were of no help. I could not see the edges of the road, which is all the fog lamps are supposed to do in inclement weather. I simply pulled over and put on my flashers ... waited for it to lighten up a little bit.
Originally Posted by Redman333
If you actually want better visibility in fog or snow, or dust than I would go with rigid's amber led lights. I don't know if they make them in the duallies size or not but they would be incredible in those situations otherwise just go with regular white duallies.
That's fine. There are many sources (which I posted links to) that provide points and counter-points on the use of fog lights. I'm not claiming I'm an expert, merely providing information that I've found. From what I've read and seen, taking into consideration that your eyes are contrast machines, they tend to focus on the brightest and nearest light source. Under 25 mph, using fog lights to light the foreground where less-than-optimal primary headlamps leave off forces your eyes to pay more attention to the foreground more, detracting from your vision (where you're actually focused) down the road. Just because there's more light in front of you doesn't mean your eyes are using it to the best of their ability, resulting in less than great overall performance.
If you have the right bulbs (towards yellow in color temp), fog lights can really help with seeing the road edges. While all my lights are LED, including the headlamps, I could not find an LED that didn't glare so I am running a yellow halide bulb. It also cuts through heavy snowfall without the glare you get with more white temp lights. I see so many people refer to any low mounted light as a fog, when really all they have is a supplemental driving light. Fog lamps are specific...I maybe use mine 3-4x per year.
I guess my point is, that if you have lights in a variety of mounting positions and with differing color temperatures, then you can adapt easier to any driving condition.
SO what all are you running? (PICS?) Also, I think you bring up a good point. Let me replace the words "Fog Light" with "Running lights." With the stock JK setup, I/we NEED running lights to augment the piss poor lighting.If I were to go with LED headlights (ie Truck-lite) do you feel that will alieveiate the need for "Running lights?" Hence, I would soley use the Rigid lights as OFF-ROAD only lights (and of course to look cool at the mall.)
I have:
Truck Lite LED headlights
Rigid Dually Flood lights mounted to rear as back-up lights
Rigid Dually Spot lights on windshield
Rigid Dually D2's (replace fog lights with custom made brackets)
Rigid 20"LED Light bar mounted on top of my bumper
Rigid 50" LED Light Bar on Roof
Here is everything on except fog lights since my high beams were on
