LED bulb swap for JK license plate?
Looking to swap out the stock halogen bulb for an LED bulb in the rear license plate frame light. Anyone know what model bulb I would need?
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
I know the size is the same as the turn signal mounted in the fender. They've got different numbers because one is less bright than the other, if I recall what I read correctly. 194 maybe??
Check out precisionled.com. I bought one of their packages that had the interior dome lights, reverse lights and license plate lights. You should be able to use their site to get some research if you didn't want to order from them.
WaterRat72 (09-23-2019)
I have a few since I had to buy a package. PM me if you still need one
BTW, karls10jk is right, its a 194, which I think is also interchangeable with the T10, 192, and 168
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
