LED accessory lites
LED accessory lites
I purchased a Gobi rack and plan on running 4 KC LED gravity lites and 2 back up lites on back of rack. Ques:
1) where can I run wires from frt lite light bar ?
2) is it poss to wire back lites into reverse lights and also a separate switch in cabin?
3) is supplied wire harness good enough or should I upgrade to spod?
Thx for insight
Thx for insight
I highly recommend the sPOD. I have been thinking about the same Gobi rack and the same questions as to where to run the wires. I have the hard and soft top, so when taking off the hard top you unhook the front of the rack and hinge back the rack to remove the hard top? Need to think about wire routing if you put up a rack mounted side lights or rear lights. Not sure about how and where the front lights mount and if they are affected by the removal of the hard top.
Love to see the pictures when you do get it on and how you wired it.
