Kicker CRV8 in factory subwoofer enclosure install.
Great job Aaron97. Looks great! I bet if you put a small class d sub amp to that it would improve it a bit more. Unfortunatley a small sub in a small box can only push just so much air. Check out rockford fosgate boosted rail amp. It's tiny but can kick up 300 watts rms and it connects to the factory wires for signal.
Originally Posted by aaron97
I've been looking at the details for the Rockford Fosgate PBR300X1. Just wondering, how did you wire up the input signals? I would think we would have to splice off the front speaker to get a cleaner signal.
So I ended up getting the little Rockford Fosgate PBR300X1 to power the sub. It will be a couple days before I can install it and let yall know how it does. I dont have a garage to work in and its been -5'F to 10'F the past couple days, so i will have to wait till it gets back into the 30's before i can stand to work outside.
Here is a picture of it. I just put the iPod Nano in there so that you can see how small the amp is.
So the sub was just pressed fit in place? There's no actual screws securing the mounting ring? If so, wow, no wonder these subs are not powered too highly - they'd blow themselves out of the enclosure!
Thanks for the information. Another item to address when my 2012 lands.
So the short version is now, the PBR300x1 does not replace the stock amp, it has to be run in conjunction with it. Its just to get more power to the subwoofer. I am going to make a bracket and mount the new amp over the stock amp, splice into the front speaker wires to get its input signal. I will then cut the 4 wires from the stock amp to the sub and use them, run in pairs so that its the same as running 2 wires.
I'm going to try it first in 2 Ohm and if its enough bass and what i am looking for, then i will keep it that way. But i still have the option of running it at 1 ohm and getting the full 300 rms watts if i need to. (Ignore this statement, I cant actually fun a 2 ohm DVC sub at 2 ohm on a Mono Amp).
Damn it... i really hate computers... ...Wasn't sure if you were referring to the Kicker sub i installed or the Infinity one, but either way, they are both securely screwed to the enclosure. In the stock sub picture, i had already removed the cover and screws. With the Kicker sub, its screwed in the same way, screws go threw the grill, sub, spacer and into the enclosure. Nothing was press fit. The stock sub just takes a little prying to get lose after you take the screws out.
