Keep my gig, change speakers, subs, add amps?
Old 07-28-2008 | 11:54 AM
Ben Hedrick's Avatar
Wait a minute... Do I even have an AMP? I have the MyGig w/ the sub woofer. Where is this amp located?
Ben
Old 07-28-2008 | 12:13 PM
Is it just above the brake pedal? I think I've found it.
Old 07-28-2008 | 02:18 PM
It's right under the steering column, behind a metal plate with two bolts in front.
Old 07-28-2008 | 02:32 PM
bodybrdng's Avatar
Does Crutchfields carry a plug and play amp and speakers for the JK? I guess I should contact them and stop bothering you...
Thanks, Ben
x2............
Yes, got it thank you.
bodybrdng's Avatar
Ben
Do you have the sub? If so then yes you do
Old 07-28-2008 | 02:46 PM
Yes I do have and the sub and the Amp. I am going to order the Infinity Kappa speakers for the sound bar and I will keep looking for the Nitro Amp.
thanks...
Old 07-28-2008 | 03:01 PM
JK-Fire's Avatar
I have the stock 7 speaker system myself and it is fine...............for the moment!! But if you want a jump in sound improvement just gut it and go for all aftermarket. So you don't even need any of the factory wiring other than power and ground. Run all new speaker wire '' Your new speakers will thank you'' and leave the factory alone.
