kc windshild light install
does anyone have or no of a diagram on how to install windshield lights, i.e how to take off wipers and cowl for the wiring? how to remove the dash to put switch down by hazzard light would be nice as well!
All I did was take the two screws out and didn't touch the wind shield wiper. I was able to lift up and just nicely tuck it under. There is a hole in the drivers side firewall that I ran my wire threw and then under the carpet to the center consult. You can buy a pre made switch set up, but I just drilled a hole and put a cool LED toggle switch in.
pics are kinda crappy, but if it helps.....
