KC windsheild lights
Those of you who have these ,
What are doing as for behind the brackets ?
Between the windshield hinge & the bracket ?
I mounted mine up temporarily but now I want to get something behind there , so it's not a metal on metal ... Pro & cons to this ?
Another thing, I've had these on for 3 months & is this a normal sight ? :( ...
I contacted KC & they offered me new brackets , so thanks ! They do stand behind these things 100% ! So not a compliant there , more so a concern to improve hardware & bracket quality .
Mine have been on all winter with no rust issues. Must have been an issue with the paint on yours. I just bolted mine up with nothing behind. Just made sure it was perfectly clean before mounting them.
You can use that colored craft foam from a craft store and cut it to fit. I have it behind mine and it works great. You just have to make sure that it is very clean behind it so you dont scratch.
well thats good to hear , Hopefully mine are just faulty ! KC is sending me replacement Brackets & hardware So maybe they will come from the good batch !!! I am still uneasy of just the metal on metal of the Windshield Mount & , i just imagine a rust tumor under them ! lol
Not a bad idea ........ Does it retain moisture against them though ? how thick is that stuff ?
I havent noticed any problems with it. Mine came with the winshield brackets. I added some for my KC light bar and so far so good. Just use the thinest stuff you can find. I think what I have is about a 1/16th of an inch thick.
As far as my 3 month old rusty brackets ! No one else with this issue ??????
Originally Posted by Cal
No issues with mine. I. Used clear tub caulking spread on the entire mount surface of the brackets to mine.
I can't believe I'm the only rusty bracket , guess good thing I got with KC for replacement of my faultys !
Have the same issue as in your pic, I had to take them off to get my windshield replaced so when put them back on I cleaned them and plasti dipped them, I guess I need to contact KC also..
